Elite Suito Garmin fenix6 sensors
d.brigljevic
Hi, I m very please user of your Elite Suito device, but my problem is that I recently bought Garmin fenix 6 and can t get them to work together. My speed is way off (around 400
) and I can t get the calibration for power to work. Please advise me what should i do so that i can watch my progress on Garmin.
Re: Elite Suito Garmin fenix6 sensors
To have correct speed, you have to set the correct circumference setting on your Garmin device.
In your case you have to set wheel circumference / 24.8 ( Example: circumference 2095 mm / 24,8 = 84 mm )
Please look at this document:
https://elitesrl.zendesk.com/hc/en-us/a ... party-apps
Notice that not all the devices allow to insert a so personalized (and low) value.
m.kurniawansyah
What is the right way to calibrate the Suito with Fenix 6x as power sensor? I have no issue calibrating with Zwift or my E training. But could not do it for my Fenix 6x. Is it not necessary?
Users browsing this forum: Bing [Bot] and 19 guests
