New Firmware 201
sambracke911
Re: New Firmware 201
Postby sambracke911 » Sat Nov 23, 2024 3:07 pm
I tried opening a ticket now also after seeing the update from @ax05035, I hope they will be able to provide a JSON file for the problems with firmware 201 as well.
Still, not great that they release a firmware which must have not been tested with Garmin devices and basically makes your trainer useless. :roll:
Hopefully a permanent fix with a new firmware version will come soon.
There really should be the possibility of downgrading to the previous version of your firmware if you are having problems, and the firmware files being available to download for that purpose. Leaving customers with an expensive useless device after installing an update is not cool.
tenbrinke1981
Postby tenbrinke1981 » Mon Dec 09, 2024 11:19 pm
Incompetence at its best, and above all without any blame 1.5 months nothing solved.
Not interested that all Suito users of misery buy another brand. :D
armellini.andrea
Postby armellini.andrea » Tue Dec 10, 2024 10:04 pm
same problem here with Garmin 840 and ant control....Is there a way to perform the downgrade to previous version?
Is there a repo with the firmware files?
pur3vildance
Postby pur3vildance » Sun Nov 23, 2025 11:58 am
thomas.bandelier wrote:this sh** bricked my suito during update - now I'm stuck in the "blue led" mode.
ANyone knwos how to recover ?
I'm in the same situation as you and I don't know how I can solve it, and I need the Elite Suito roller to be able to train.
elflatero
Postby elflatero » Thu Nov 27, 2025 1:40 am
Tengo el mismo problema desde el domingo 23/11
Return to “Suito”
