Issue with every Garmin product
Re: Issue with every Garmin product
Has anyone solved the problem?
Yes.
Contact support, they will provide .json file to upload via Upgrado.
I could paste .json content, but I don't know if it is universal, for different hardware revisions or file I got works only with mine hardware revision, so better not paste it here.
Dunno why they do not push update to Upgrado and only distribute it to people who asks for it.
Response I got.
Dear Customer,
The issue you reported is caused by a temporary malfunction in My E-Training, which prevents disabling the new feature available for the Suito trainer in Stand Alone mode.
Additionally, the way Garmin sends the power signal, which is too infrequent, results in the automatic activation of this feature during use in ERG mode. Please note that any other app sends signals much more frequently, significantly reducing such issues. Our developers are already working to resolve this situation as soon as possible.
In the meantime, to disable this feature and address issues related to ERG mode with Garmin devices, please follow these steps using a JSON file:
Download the JSON file attached to this communication.
Follow the instructions to execute the JSON file with Upgrado, as outlined in our Knowledge Base article:
Execute a JSON file with Upgrado
Please let me know if the issue has been resolved after completing the procedure.
If you have any questions or need further assistance, do not hesitate to contact us.
Best regards
Response I got.
Dear Customer,
Best regards
Hey, I also have the same problems with my Suito + Garmin. Can someone send me the .json file? Thank you
aaltairnsk
My Suite with fw 201 stopped reset ERG settings every few seconds after applying json file.
But it still loses ERG settings from time to time. For example 30 minutes stage on fixed power may be successful but often not. Typical time of loosing settings in standalone mode (as we now know it is equivalent of garmin rarely commands sending ) is about 10 minutes.
Else one issue with fw 201 is trainer sensors i.e. its data became more unstable. Together with the ERG failure speed may jump to random high value to few seconds.
And with both fw 201 and earlier all sensors may fall to zero value time to time for few seconds.
stephen.podmore
I have been able to load the file to the upgrado app but whilst it says the file has been imported and is selectable in the update procedure, there is no option to select it?
anyone able to help?
stephen.podmore
polinik wrote:Yes.
Response I got.
Dear Customer,
Best regards
Hi polinik,
Did you successfully install it? see my earlier post....
Steve
Hi all,
the issue obviously still exists.
1 year later I am facing exactly the same problem with my Garmin Edge 830 and Elite Suito.
The resistance is held for exactly 15 seconds then it falls back to a preset value.
A few days ago I have updated the trainer firmware trying to solve the problem with an update. But it did not help.
A possibility to activate/deactivate the standalone function is not given.
So what is the solution now ?
I read about a JSON file ?
Is that the way to go ?
And if so, how can I get that file.
Thanks and best regards
Hello Elite Team,
isn't it possible to give a short information or to reply on the message which I have already left with the contact form ?
I still have this issue with the Suito and Garmin egde.
Does nobody care ?
Does nobody care ?
