Problems after firmware update
edecast
Postby edecast » Wed Jan 24, 2024 5:23 pm
I just tried to update the firmware of a Suito and there must have been some problem (it's been going on for a long time, and I don't think it ended well) and now it doesn't pair with the Garmin, nor am I able to get it to happen in the UPGRADO application now of screen". It seems that it reads that the firmware is 196 but without showing data in the HW revision, and it also stays on the app screen with the "little clock" without going beyond there. I don't know if there is any way to "reset" the roller to factory settings or something similar, or if there is a contact email for ELITE technical support that I can contact, which I haven't located either. Thank you if anyone can comment.
ymarti.ymarti
Re: Problems after firmware update
Postby ymarti.ymarti » Thu Jan 25, 2024 7:07 am
My suggestion is to repeat all setup starting to zero, like new.
And then to repeat the connection to garmin
GOD SAVE THE RIDER
edecast
Postby edecast » Tue Jan 30, 2024 12:42 pm
ymarti.ymarti wrote:My suggestion is to repeat all setup starting to zero, like new.
Thanks ymarti. After several repeats I finally done OK
ymarti.ymarti
Postby ymarti.ymarti » Wed Jan 31, 2024 1:55 pm
Great!
Have a good riding!
GOD SAVE THE RIDER
michaelarrington
Postby michaelarrington » Tue May 07, 2024 9:21 am
Some devices have a way to recover from failed firmware updates, such as using a specific software tool or connecting to a computer via USB. Again, check the user manual or the manufacturer's website for any information on firmware recovery for the Suito trainer.
fnaf
tonyadams
Postby tonyadams » Wed Jul 31, 2024 11:44 am
I recommend turning off both your Suito and Garmin device, wait a few minutes, and then turn them back on. Retro Bowl College
Return to “Suito”
