Integrated power meter not working
sebastian.hochgatterer
Postby sebastian.hochgatterer » Tue Feb 08, 2022 7:45 am
my Suito doesn't show any power in watt on a training in the "myETraining" app.
From my understanding this trainer has an integrated power meter and there is no need for an external over PML.
Trainerdiagnostic complete successfully and recalibration didn't have an effect.
Could you give me some advice what I can do?
Cadence - working
HR external - working
Powermeter - not working
Firmware : 196
HW-Revision: 009
BR Sebastian
Re: Integrated power meter not working
Postby Elite Admin S » Tue Feb 08, 2022 1:44 pm
Suito hasn't got a integrated power sensor, but it calculates power from speed.
Probably you have done a wrong configuration.
Repeat it and when you're asked if you have power or cadence sensor, leave the option on NO (this option is used only for external sensors).
This will solve the problem
tobiasschmitzhaus
Postby tobiasschmitzhaus » Sat Aug 20, 2022 6:21 am
I have almost The same problem.
No power and no cadence readings.
But I just cant connect my etrainng to suito. It doesnt work! Ziwft, ok...but my etrainng no...
How can I solve?
Postby Elite Admin S » Mon Aug 29, 2022 8:56 am
If you've already checked the configuration, contact our support:
Return to “Suito”
