Suito Calibration with PML
joerg.encke
Postby joerg.encke » Fri Dec 24, 2021 1:32 pm
Hi, I'm using the suito with PML. Is it still necessary to calibrate the trainer or is it sufficient to calibrate the Power meter?
Cheers?
Re: Suito Calibration with PML
Postby Elite Admin S » Tue Dec 28, 2021 10:17 am
If you use the PML, power comes from your power sensor.
So, it's not necessary to calibrate the trainer
mjv144
Postby mjv144 » Thu Feb 24, 2022 7:05 pm
If I don't use PML?
If I connect my external/separate power meter (to zwift), will I still need to calibrate my Suito-t trainer?
Postby Elite Admin S » Mon Feb 28, 2022 9:27 am
No, it's not necessary
mjv144
Postby mjv144 » Mon Feb 28, 2022 2:23 pm
Thanks!
Return to “Suito”
