New Gravel Bike Compatibility?
ashimon
Postby ashimon » Wed Jan 19, 2022 11:05 pm
Considering getting a new state street gravel bike and wanting to use it with my Elite Suito. The bike has a rear thru-axel of M12 156mm. I see a 157mm thru axel booster adapter would this work, or should I keep looking for another bike?
red.hell
Re: New Gravel Bike Compatibility?
Postby red.hell » Thu Jan 20, 2022 9:33 pm
it's not the axle length important, but the hub width
with 156 mm axle it's probably a standard 142 mm hub width, so it's compatible without any accessories
ashimon
Postby ashimon » Fri Jan 21, 2022 9:00 pm
You are indeed correct, the hub width on the rear is 142mm, thank you for the insight, I appreciate it. :)
Return to “Suito”
