Nero rollers power reading lag
stephen982
Postby stephen982 » Tue Dec 21, 2021 1:37 pm
I bought a set of elite nero rollers around 4-5 montgs ago, they have worked amazingly well until 2 days ago (19 December 2021) when I noticed a severe lag in the power reading on zwift, the power slowly increased from 0 till it reached the actual power output around 20-30 seconds later.
The same happens when the power is reduced, it takes around 30 seconds to register and drop the power reading to the actual power.
This used to be instantaneous change as power readings should be.
I disconnected from zwift and connected to my garmin Edge 820 only, and had the exact same issue.
I have done all calibration methods multiple times, but no success.
How do I go about fixing this?
Re: Nero rollers power reading lag
Postby Elite Admin S » Wed Dec 22, 2021 10:00 am
Are you using PML (power meter link) with your Nero?
If it is so, try disabling it and tell me if you have the same issue
warn
Postby warn » Mon Sep 11, 2023 10:53 am
Hi stephen982,
is this the same issue as I described in topic 3840? If so, it just appears when using Power Meter Link.
Kind regards
Return to “Nero”
