elite volano smart B+ crazy speeds
Posted: Fri Jul 16, 2021 9:29 pm
by neilnorthcott
hi,
have a Volano B+
connect it to sufferfest via ANT+ and the speeds it shows seem way out.
i mean i dont think im really averaging 147KPH on an Hours work out or hitting top speeds of over 350KPH! :shock:
i'm having to use "sufferfest speed" when using the program
i have also had it connected up to my wahoo training app and it shows the same thing massively over rated speeds.
the candence seems fine
the power (watts) i m not sure if that completely right (it seems a lot lighter in lower gears then when i was using a BKOOL ONE with a speed and cadence sensor)
ive used the update app to check that misuro B+ firmware is upto date and it is.
any info would be greatly received.
Re: elite volano smart B+ crazy speeds
Posted: Wed Jul 21, 2021 8:06 am
by Elite Admin S
When you use a non elite device or app, you have to set the circumference properly (considering the internal ratio).
You have to divide your wheel circumference by 25,34.
Look at this article:
https://elitesrl.zendesk.com/hc/en-us/a ... party-apps
