Hello
I have one big problem with mine misuro b+. i had uploaded myetrainer and instaled misuro b+ on nova Force, but i don't get no conection with mine mobile ( samsung a51 ). What did i do wrong , maybe something in setting ?? I don't have none other sensors just Nova force 8. Misuro is set on 1 blink, but when you want too find him with bluetooth mobile says that i need some app. When i m pedelling there is no connection. Just tell me where did i do wrong and how to fix this problem.
Novo Force 8 + misuro b+ bluetooth conection ?
- force2.jpg (106.92 KiB) Viewed 13464 times
- force1.jpg (163.28 KiB) Viewed 13464 times
- force.jpg (241.05 KiB) Viewed 13464 times
Re: Novo Force 8 + misuro b+ bluetooth conection ?
have you installed the small magnet on the roller? Check also that Misuro B+ is correctly placed on the rollet. Try also to connect the mobile device with ANT+ instead of bluetooth.
Best regards,
Mauro
Best regards,
Mauro
I had fix the problem. Iphone did on android didn't work( but i must try again , becouse i fix position for misuro b+ for some 1-3 mm ) Now myetrainer work, but zwift still not. So is 50 % victory for me.
