Problem with read Power Elite Aleno
pdonati@gmail.com
Postby pdonati@gmail.com » Mon May 13, 2019 9:28 am
I bought an Elite Aleno last December and using around 3 months and no problems.
I return to use my Elite Aleno this month and I have verified that the Power (W) readings are not correct.
Today, for example, was using the Elite Aleno with the program Zwift and in the first half hour, the readings of Cadence, speed and powers were correct. However, after half an hour, the power readings began to vary around 40W upwards.
For example, without changing the bike's gearshift and roll resistance, the power reading was 153 W with cadence at 86 RPM. 3 Seconds later maintaining the same cadence and without changing any configuration, the power read was of 217W.
I have verified that this is happening with a certain frequency.
Today before starting my workout, I changed the battery.
I would like to know what can be happening to this variation and if it is possible to make some type of configuration so that it works again correctly?
see attached 2 pictures demonstrated what happended
