Power smart b+ and power mag smart b+ are they the same product?
Alex
Power smart b+ vs power mag smart b+
Re: Power smart b+ vs power mag smart b+
Hi Alex
It should be... but sometime the shops do some confusion with names, so if you send me the links to the products I'll check for you the model
regards
regards
