Turbo Muin Stopped connecting with APP
Posted: Thu Aug 09, 2018 2:40 pm
by renato.tumang
HI I bought an Turbo Muin Smart B+on January 2017. And some days ago it stopped connecting with Smartphone APP. It keep asking me to start riding, but I start and the connection is not set. Would you please help me? Is there a Battery inside the Trainer that I should change?
Thanks.
Re: Turbo Muin Stopped connecting with APP
Posted: Tue Aug 28, 2018 9:15 am
by Elite Admin S
Probably it's due to the battery.
On the lower part of the trainer, you should see a red plastic tap. Inside, there's a sensor (misuro B+).
Open it and change the battery.
On the user manual you can easily find the procedure to change battery.
Posted: Tue Nov 27, 2018 5:26 pm
by renato.tumang
HI,
Drivo II needs to change battery too? Calibration failed but the trainer has 3 months only.
Thanks.
Posted: Mon Jan 14, 2019 2:20 pm
by Elite Admin S
Drivo doesn't use batteries. It has a power supply.
Usually a failed calibration is due to disconnections (interference).
Please try again (also with a different device) and if the problem persists contact our customer care at myetraining@elite-it.com
Posted: Wed Jul 24, 2019 6:56 pm
by zeloviqyw
What The Fuck? The word itself sounds bad in it and how a person will feel if you say that to him. The speedypaper reviews can teach you about good vocabulary and grammatical term. So, stop bothering the other guys with the improper forms.
