TurboMuin B+ and Garmin Edge810
rickpuskar
The Turbo Muin B+ supports ANT technology and so does the Garmin Edge 810. For some time I've read where you will support this device (the line of Garmin devices) for easier transfer of data from the Turbo Muin to the Garmin. Today it's all manual. Can you help here please?
Re: TurboMuin B+ and Garmin Edge810
Good morning
I'm not sure to have understood what you mean by "easy transfer of data".
The Turbo Muin Smart B+ sends data via ant+, so you can connect your Garmin to the trainer as a speed&cadence sensor plus a power sensor.
If this is not what you're asking for, please can you try to explain it to me again?
