Turbo Muin Smart B+ - no device found on Macbook Pro
Posted: Mon Dec 11, 2017 11:25 pm
by xsenna
My Macbook Pro (2017) cannot pair with Turbo Muin Smart B+ S/N: 48518 using Bluetooth. Neither Zwift nor MyETraining app finds the device. MyEtraining app states: device not found. However, my older Macbook Air and my Iphone find the trainer without issues.
My Bluetooth connection on the Macbook Pro is switched on and other devices are found without issues.
How can I fix that?
Re: Turbo Muin Smart B+ - no device found on Macbook Pro
Posted: Wed Dec 20, 2017 1:02 pm
by Elite Admin S
My e-training Desktop pc version doesn't support the Smart trainer yet (only the interactive ant+ fe-c trainers).
We will add the smart trainers in few months.
With Zwift you shouldn't have any problem.
Please send a screenshot with the configuration you've set in Zwift so I can check it.
