Hi Folks,
I've managed to set up my Muin B+ trainer so it has connected to both the power & the cadence but I'm wondering if it should also be able to connect to the 'Controllable' on Zwift?
I haven't been able to connect it with either Bluetooth or ANT+.
Am I missing something?
Thank you!
Turbo Muin B+ connection issue.
Re: Turbo Muin B+ connection issue.
Turbo Muin smart B+ is not an interactive trainer.
You can do this only if you have a Real Turbo Muin B+
