Hi.
I´ve an old Turbo Mein (serial no. 17489). Till date I´ve used a Misuro Blu together with the My E-Training App and it worked well. Recently I wanted to start with ZWIFT but couldn't connect the sensor with the App. After several trials I´ve decided to buy a new sensor - MISURO B+ (>50€).
Now I´ve the next problem. I can´t at all connect this sensor with the My E-Trainign App!! I follow the complete configuration in the App but there is absolutely signal coming from the sensor to the App. I´ve also adjusted acc. to the required blink pattern (2 times for Turbo Mein S.No 17489) but it´s still not working. I´ve tried to move the sensor on the TM but without success. At the beginning I had at least a signal with only 0.5-1.0km/h and max. 5 Watt This can´t be.
I´ve tried a lot and reviewed different forums but without success! Hope you can somehow help.
Thank you,
Michael
Turbo Muin - connection problem MISURO B+
