Turbo Muin Smart b+ oil seal
dubzter
Postby dubzter » Mon Aug 17, 2020 6:05 pm
Hi it looks like the oil seal on the non drive side of my Turbo Muin B+ is starting to fail. I’m getting some drips of oil when the trainer is in use. Can anyone point me to somewhere I can purchase the oil seal and also what kind and quantity of oil do I need to replace.
Re: Turbo Muin Smart b+ oil seal
Postby Elite Admin S » Tue Sep 01, 2020 12:33 pm
Contact our customer care at myetraining@elite-it.com.
We will give you instructions on how to check where the leak comes from and send you the replacing parts if necessary
Return to “Turbo Muin”
