I just have sent a message though the contact form in the support of the official website, but I would like to ask here also.
I have a Turbomuin (2014) and after some time without using it, I discover today oil on the floor.
I remove the cover and the rubber seal seems not to be well positioned.
Do you have replament for this rubber seal?
How much oil I have to put inside? (Because I don´t know exactly how much oil has he lost)
What kind of oil uses the TurboMuin?
Thank you very much
Oil loss in TurboMuin
Re: Oil loss in TurboMuin
I've been told that you're already in contact with our customer care to solve the problem.
The oil to use is a special oil, so we will send it to you (and also a new o-ring)
