Hello
My Turbomuin Misuro+ has started to vibrate when pedaling. The vibrations seems to come from the flying wheel. I got it for almost three years now and has been very pleased with it since. What can I do about it ? Should I open it ?
Many thanks
Alex
Vibrations
brianppbyrne
Re: Vibrations
I have the same issue. I took the cover off it to discover that the black plastic belt roller was deformed. Not sure if it's still available as the unit is now discontinued.
I'm going to try and improvise and see if I can replace it with a bearing that has the same inside and outside diameter.
Brian
Brian
chessamanuel
Re: Vibrations
Io ho lo stesso problema ma il mio cuscinetto
È normale...
cosa potrebbe essere?
Grazie
È normale...
Grazie
