got a new Turno and the CR2032 last just 1-2hours. I connect the Turno with a Garmin Edge 530.
Is this normal?
Turno and Battery Lifetime
Re: Turno and Battery Lifetime
probably the cr2032 was old and nearly empty. just replace it with a new one and it should work. mine was empty after just a few months. after replacing it lasts for about one year. maybe less or more depending on usage. I connect the turno (misuro) with a forerunner 245 for heartrate and cadence but i don t think the garmin effect any batterylife of the misuro sensor.
hope it s helpful. best wishes michael
I have the same problem.
I used a new batterie and after 2 h the program says "low battery" ????????????
mywhoosh and garmin 830
