I would like to know if my turno is calibrated well. I was looking at the power curve https://drive.google.com/file/d/0B_4_od ... hDcjg/view
i've done a workout with myetraining and upload to strava
On the attached file i was about 30Km/h as if the power cuver is right i should be close to 390w
tks
Turno Power Curve
Turno Power Curve
- test.jpg (15.81 KiB) Viewed 15610 times
Re: Turno Power Curve
Every Turno is slightly different from the others, due to internal mechanical tolerances.
All Turnos have the assembled Misuro B+ sensor with saved the power curve measured for its hometrainer during the production, so there will be little differences between the hometrainers.
In your case, you have a speed of 29.7 and a power of 321W. This value is absolutely inside the range it should be.
bonjour,
j'ai le même problème. je roule avec des amis sur ZWIFT.
nous sommes à la même vitesse, ils sont à 3WATTS et moi 4watts. Du coup je ne peux pas tenir la sortie. est-ce qu'il y a un réglage à faire ?
Merci
Merci
