ELITE KURA + POLAR V800 - Speed problem
WINI
Postby WINI » Sun Feb 18, 2018 2:54 pm
Dear forum members,
I am new to this forum, that why I am asking for your understanding. (at the beginning I tried to find a similar topic / discussion but I can't found nothing, that why I ask you for support)
I am the new user of the "KURA" Trainer Elite in combination with the Polar V800 sports computer.
After several trainings, I noticed that the speed and the distance traveled is wrong (many times higher than it actually should be).
In the computer settings: Polar sets up:
- crank length: (172.5)
- circumference wheel (2150) - Same like in 28'' - bike has)
it seems logical that the value of the circumference of the wheel should be different - after the bike is put in the KURA Trainer - nevertheless I'm not able to set lower value in my POLAR V800 Computer: like 1000.
Dear members have you found similar problems - how can I solve this problem?
Any ideas for support?
Dear Elite Service Specialists - can you have any idea for this problem - how to solve it?
Best Regards
Wini
Re: ELITE KURA + POLAR V800 - Speed problem
Postby Elite Admin S » Thu Feb 22, 2018 11:12 am
You have to insert in your Polar a circumference value that also consider the internal ratio of the trainer.
In your case, you have to set a circumference equal to your wheel circumference divided by 3.43.
So, for example, if your wheel measure 2100mm, on the Polar you have to set a circumference of 612mm.
Not all the Polar (or the Garmin) allow to insert a so low circumference value unfortunately.
Check with the manufacturer if it is possible for your model.
WINI
Postby WINI » Sun Mar 04, 2018 7:12 am
Thank You for your explanation and support.
I already contact Polar - and now I'm whait for the information from them.
I will inform you what will be the final results of our descoution.
Best Regards
Marcin
Migo
Postby Migo » Sun Apr 01, 2018 9:05 pm
I have the same problem with the Polar V800 and the Elite Direto. The speed shown on my watch is 10x higher than the speed shown in Zwift. Is there a know fix for this issue? The circumference in the V800 is set to the same value as the in the Direto. Zwift shows the correct speed with the same settings.
laurent.lach
Postby laurent.lach » Thu May 10, 2018 4:21 pm
Hi! Same issue there with V800 and Elite Direto: we would need to divide the circumference in mm by 12.1, but in Polar V800 we cannot set values so low for the circumference... :shock: Very disapointing...
Postby Elite Admin S » Fri May 11, 2018 9:36 am
Guys,
as speed is calculated on the number of turns of the fan (where the magnet is) and not on the number of wheel turns, you have to divide the wheel circumference by the ratio of the trainer (12.1). If Polar doesn't allow you to insert this value, contact Polar and ask if there's a possible solution.
Return to “Kura”
