Circumference settings
TPR
Postby TPR » Mon Sep 17, 2018 8:17 am
I am using Elite Kura and I'm asked to enter wheel circumference in two places:
1. My ETraining app
2. Garmin 735xt watch
What should I enter in both of these? Should these be normalised values or actual ones counting rim size AND tyre size? I use 700c wheels.
AFAIK Elite Kura actual circmuference is 603 (this is the value I should put into my garmin or any other 3rd party device)? But when I enter this it shows my speed as less than 20kmh with ~160watts (I'm 79kg), which doesn't make sense (it's too little). But when I enter ~2000 there, it shows I'm 50kmh with the same wattage.
So what should I enter? :geek:
Re: Circumference settings
Postby Elite Admin S » Tue Sep 18, 2018 9:40 am
The values you're using are correct.
Consider that Kura is not a simulator, its power curve grows up very quickly (far more than what you'd have on a real road training).
Let's have a look at the Kura power curve:
As you can see, if you are riding at around 20km/h you are already developing around 200W.
That's how this kind of trainer works.
Here you can find a document that explains well this point (it's about Turbo Muin, but the concept is the same):
Return to “Kura”
