Calibration
Posted: Mon Feb 05, 2018 9:28 am
by timo_schultz
Dear all,
I need your help:
I have a Real Turbo Muin B+ and a Arion Digital Smart B+. On my bike I have a Power2inpower as powermeter.
Saturday I did a FTP Test with my Powermeter and the Turbo Muin. The power on the combination Rotor/Fenix5 Shows me about 50 Watts less than the combination Turbo Muin/Edge 1000. On Sunday I rode my bike on the Arion Digital, there the combi Rotor/Fenix5 Shows about 30 Watts more than the Roller/Edge.
I think there is a calibration mistake.
Also, if I connect my Fenix to one of both Trainers, I always ride more than 100km/h. The Edge Shows me more realistic velocity.
The App My Etraining gives the oportunity for "professional configuration" with circumference etc. Is there a manual how to calibrate the Turbo Muin. / Arion Digital Smart B+?
Thanks for your help
Re: Calibration
Posted: Mon Feb 05, 2018 6:07 pm
by sebrios
did you try adjusting the wheel size in the software? (I found that helped me) .. that, and the Riders weight
...just my opinion, might be wrong thou
Re: Calibration
Posted: Mon Feb 05, 2018 8:04 pm
by timo_schultz
Yes, I already tried! There is a exmaple how to get the right circumfence. I am wondering about the differnce in eng / ita:
ITA: - dividere il valore per 3 , per calcolare l'effettiva circonferenza della ruota
ENG: - divide by 2, to calculate the actual circumference of the wheel
I am not a native speaker of ENG or ITA, but 3 is not like 2?!?!
Best regrads
Timo
Re: Calibration
Posted: Mon Feb 05, 2018 8:28 pm
by sebrios
Try this site. I always use it:
http://www.bikegalerie.de/de/berechnungstools/radumfang
just put the resulted number.
when using the Elite software, you do NOT need to divide anything (software makes it internally)
Re: Calibration
Posted: Fri Feb 16, 2018 10:48 am
by Elite Admin S
@timo_schultz,
The two procedure are almost identical, but in the italian one it is written to do 3 turns of the wheel and then divide by 3; in the english one it is written to do 2 turns of the wheel and divide by 2. It's the same. More turns, more precision (but really, you'd get the same value at the end as you remove the decimals).
