Arion Digital Smart B+ vibrating
alvarezkeko
Postby alvarezkeko » Sat Sep 19, 2020 4:35 am
My Arion Digital Smart B+ is vibrating on the two rear rollers, will it be the belt? Is there any way to maintain the drums?
Sergio Alvarez
Guerrero, Mexico
Re: Arion Digital Smart B+ vibrating
Postby Elite Admin S » Mon Sep 21, 2020 9:29 am
It's more probable something on a drum.
Please contact the customer care at myetraining@elite-it.com.
kevb99
Postby kevb99 » Wed Oct 14, 2020 3:22 pm
Did you get a solution to this, I have similar
dydavide
Postby dydavide » Sat Dec 26, 2020 6:04 pm
Guys,
try to move the single roll on its axis (not radial or tangential, just on its axis). It there is some space, you need to tie the screws once you remove the plastic black cover on the side
Return to “Arion Digital”
