Speed help
Re: Speed help
All - thanks to working with Wahoo - they have now 'fixed' this. The fix is the ability to set the wheel circumference to a very small number in the Elemnt app. It's a work-around, but a good outcome and solution to a problem which Elite should never have created...
Re: Speed help
antbarron wrote:All - thanks to working with Wahoo - they have now 'fixed' this. The fix is the ability to set the wheel circumference to a very small number in the Elemnt app. It's a work-around, but a good outcome and solution to a problem which Elite should never have created...
Hi ,I have the same problem with Suito connected with Wahoo bolt. I try to control the trainer with Elemnt bolt.
I set wheel circumference at 0.088m as Elite mention on the manual. Then speed working well until it went to 15.7KPH and It went to 0.5KPH.
Please advise how to solve this problem
Re: Speed help
I have also the same configuration:
- Wahoo Elemnt Bolt
- Elite Suito
and I cannot find the right configuration for wheel circumference. Setting the one shown in the manual (0.084m) the speed is completely wrong (rises at about 30 kph, then loses the value and finally set at about 3kph.
Is there a solution for the issue?
- Wahoo Elemnt Bolt
- Elite Suito
Re: Speed help
I'm having the exact same issue with Elite Suito paired to a Wahoo Elemnt Bolt.
Filed a ticket, so hopefully something that will be fixed eventually.
Re: Speed help
Did you find a solution or any answer to your ticket? I have the same problem
Re: Speed help
Hello team, I have a problem with speed and distance, I hope someone will help me with this, namely in the beginning everything worked, sometimes it was lost for a few seconds and then came back, I use the wahoo element bolt device to which my ELITE SUITO-T is connected, I typed in ELEMENT wheel size application that I found on the forum, but the dimensions are not good, it goes up to 39 km/h and then stops, it does not show any more, so if anyone knows how to fix it, I would be grateful. Thank you.
Re: Speed help
@bubasmario
I've replied you in the other post you raised
