Speed help
antbarron
Re: Speed help
Postby antbarron » Mon Aug 19, 2019 4:15 am
All - thanks to working with Wahoo - they have now 'fixed' this. The fix is the ability to set the wheel circumference to a very small number in the Elemnt app. It's a work-around, but a good outcome and solution to a problem which Elite should never have created...
danai.nawa
Re: Speed help
Postby danai.nawa » Mon Feb 17, 2020 6:06 pm
antbarron wrote:All - thanks to working with Wahoo - they have now 'fixed' this. The fix is the ability to set the wheel circumference to a very small number in the Elemnt app. It's a work-around, but a good outcome and solution to a problem which Elite should never have created...
Hi ,I have the same problem with Suito connected with Wahoo bolt. I try to control the trainer with Elemnt bolt.
I set wheel circumference at 0.088m as Elite mention on the manual. Then speed working well until it went to 15.7KPH and It went to 0.5KPH.
Please advise how to solve this problem
manurosso87
Re: Speed help
Postby manurosso87 » Thu Apr 02, 2020 6:06 pm
I have also the same configuration:
- Wahoo Elemnt Bolt
- Elite Suito
and I cannot find the right configuration for wheel circumference. Setting the one shown in the manual (0.084m) the speed is completely wrong (rises at about 30 kph, then loses the value and finally set at about 3kph.
Is there a solution for the issue?
gielklanker
Re: Speed help
Postby gielklanker » Thu Apr 02, 2020 10:22 pm
I'm having the exact same issue with Elite Suito paired to a Wahoo Elemnt Bolt.
Filed a ticket, so hopefully something that will be fixed eventually.
derboo
Re: Speed help
Postby derboo » Mon Apr 12, 2021 2:24 pm
Did you find a solution or any answer to your ticket? I have the same problem
bubasmario5
Re: Speed help
Postby bubasmario5 » Wed Nov 22, 2023 10:19 pm
Hello team, I have a problem with speed and distance, I hope someone will help me with this, namely in the beginning everything worked, sometimes it was lost for a few seconds and then came back, I use the wahoo element bolt device to which my ELITE SUITO-T is connected, I typed in ELEMENT wheel size application that I found on the forum, but the dimensions are not good, it goes up to 39 km/h and then stops, it does not show any more, so if anyone knows how to fix it, I would be grateful. Thank you.
Re: Speed help
Postby Elite Admin S » Thu Nov 23, 2023 8:37 am
@bubasmario
I've replied you in the other post you raised
