Hi, I'm trying to connect the Rampa with our new Dell XPS-13 laptop via internal Bluetooth without success.
Can you please help?
thanks!
Can't connect Rampa to Zwift on Laptop via Bluetooth
Re: Can't connect Rampa to Zwift on Laptop via Bluetooth
If your machine hardware supports the bluetooth LE, you should be able to connect.
Contact Zwift to check if there's something particular you have to set
