Garmin Edge as FE-C unit
Posted: Fri Jun 19, 2020 11:29 am
by jim802
Hello
When setting up the Garmin Edge 820 with Arion Digital Smart B+, in the settings I am asked for a few things that I am not sure about.
Circumference - I know I can leave this field blank as have seen in the FAQ section
Bike weight - is this needed?
Gear ratio - is this needed?
Thank you
Re: Garmin Edge as FE-C unit
Posted: Mon Jun 22, 2020 9:49 am
by Elite Admin S
If you connect the trainer as a fe-c trainer, circumference and ratio are not needed.
About weight, it may be needed for calories calculation I suppose, but you should ask Garmin directly
Posted: Mon Jun 22, 2020 11:49 am
by jim802
Thank you
I will leave these blank.
