I've been trying to connect to my Elite SUITO using a ANT usb stick with no luck so far.
(AntWare2)
Can someone help me regarding this topic?
Thanks in advance
ANT FE-C connection to SUITO
Re: ANT FE-C connection to SUITO
Which ant+ usb stick are you using? Is it certified?
Are you using a pc or a Mac? Your operative system is recognizing the ant stick properly?
If you use my e-training instead of AntWare II and try to connect to the trainer using that usb stick, are you able to connect?
davidluterancik
I am using the Elite stick on PC. The stick works fine with zwift, however i need to create my own soltioun for Unreal Engine
Can anyone help me or guide me to the FE-C tutorial?
davidluterancik
I tried going over multiple tutorials and formus,
https://www.thisisant.com/forum/viewthread/4282
this post appears to have same issue solved by ANT-FS, using the pre-set key for ANT-FS from the library still no luck connecting
