The WAT output no longer changes on Zwift.
wakamatsu
Postby wakamatsu » Fri Jul 19, 2019 7:09 am
I am using the old "Real E-motion"(not B+) for two years.
Until now, Zwift worked without any problems, but from July 17th, Wat output does not change at zero or constant.
May be related to the 16th day of zwift's automatic update.
It works without problems on "Software Real"(the output changes normally).
Aren't you anyone having the same problem?
fredrik.blad
Re: The WAT output no longer changes on Zwift.
Postby fredrik.blad » Thu Oct 17, 2019 10:06 pm
I have the same problem. Anyone know how to fix it?
