Hi all, I like to use the planned workouts function on the Wahoo Elemnt with my Qubo Digital Smart B+, but I cannot get the computer to display power on screen. I've contacted Wahoo about it and they are looking at the logs to see what's wrong, because they insist it shouldn't be a problem.
Has anyone else encountered this issue, and if so, have you been able to fix it?
Thanks in advance for the help!
Help needed with Qubo Digital Smart B+ and Wahoo Elemnt
Re: Help needed with Qubo Digital Smart B+ and Wahoo Elemnt
is this still an issue? I've got the same trainer and I an thinking of buying a wahoo elemnt bolt.
Best regards, Adrian
i have same issue, probably ANT connection is passive, not active. Only read data from qubo could someone from elite support answer this?
Various users have told us that there seems to be a problem with speed using Wahoo Elemnt (but it should be only for the smart trainers).
But you should be able to connect properly an ant+ fe-c trainer (like Qubo Digital Smart B+).
Please check in the settings if you've connected it as a interactive trainer and not as a speed&cadence sensor only. If it is configured as a sensor only, you could see the data but won't be able to control the resistance.
For any doubt, please contact Wahoo customer care (as we don't know exactly how it works).
