No resistance on zwift pc with Rampa
edison
Postby edison » Fri Jun 15, 2018 4:07 am
- Device: Elite Rampa
Issue is described below:
1. resistance ok(varies) on zwift iphone veriosn
but
2. no resistance on zwift pc (ant+ connected)
Please figure out.
Re: No resistance on zwift pc with Rampa
Postby Elite Admin S » Fri Jun 15, 2018 9:24 am
Are you sure that the trainer is not still connected to the iPhone?
The ant+ dongle is properly recognized by your pc (check on windows device manager)?
Check also if you have installed other software that can occupy the ant dongle at start up (like Garmin Express) and in case uninstall them (or kill th process using task manager before running Zwift)
If all the points above are ok, try in this way:
- turn off your iPhone
- power off Rampa
- restart your pc
- run Zwift
- do the configuration
If still you are having problems, please send a screenshot of the configuration you've set so I can check it.
