I would like to write my own application to be able to control my Elite Suito trainer.
Is there an API or SDK that will allow me to do it?
Do you have documentation for developers?
Enabling such option for your trainers has a growth potential.
Thank you,
Uri
SDK/API to Elite Suito trainer
Re: SDK/API to Elite Suito trainer
Suito uses standard protocols (bluetooth FTMS and ant+ FE-C) which are public.
You can find the documentation around the net.
About ant+, I suggest you to start from this site: https://www.thisisant.com/
