Calibrate Real Turbo Muin B+
Posted: Tue Feb 06, 2018 3:12 pm
by jabped
Hi.
I have got a real turbo Muin B+.
I want calibrate It but i can't do It.
I follow the instructions but, when i reach the speed (30 km/h) the trainer does nothing.
Some idea?
Re: Calibrate Real Turbo Muin B+
Posted: Fri Feb 16, 2018 11:15 am
by Elite Admin S
I see that you're already in contact with the customer care to solve the problem.
The technician is still waiting your reply to understand better the situation (it seems a disconnection issue)
Posted: Fri Dec 14, 2018 6:19 am
by tycho_mx
I have the exact same issue.
I actually get to do the second part of the pedalling - the more intense one. On my bike's power meter it was around 340 W. I pedalled as long as I thought it was reasonable (about 7 minutes) then just gave up on it. Tried again but no luck.
What would be the best way to address this? Currently the readings on the power meter are about 10-15% higher than on any of other 3 bikes at a given speed, diverging wider at higher intensities.
Rod Diaz
