real emotion resposiveness
Posted: Mon Jun 26, 2017 10:00 am
by loki
i noticed a lag of 1-2 seconds until the magnet gives me the resistance of a slope in zwift ... is there any possibility to fasten this procedure ?
Re: real emotion resposiveness
Posted: Mon Jun 26, 2017 12:33 pm
by Elite Admin S
It is due to how the trainer is made.
The trainer has a magnetic arm moved by a step motor, so it takes some seconds to put the arm in the correct position.
If you have a b+ version or an ant upgradable version of the firmware, you can indeed speed it up a little.
In this case, here's the link on how to do it (look for the part related to modification of the resistance variation speed:
http://com.elite.realaxiom.static.s3.am ... _eng_5.pdf
Posted: Tue Jul 04, 2017 11:26 am
by loki
i have the b+ version and downloaded the tool for the b+ version but it told me that the trainer is not supported.
Posted: Tue Jul 04, 2017 11:39 am
by Elite Admin S
Sorry, I've verified and Real Emotion is already at its maximum speed.
This part of the procedure is almost only for Real Turbo Muin.
I'm sorry, it's not possible to speed it up.
Posted: Thu Jul 06, 2017 8:17 am
by Elite Admin S
@loki,
Good news!
I've talked with the developers again and they told me that they can indeed speed it up a little!
They are modifying the upgrade program to enable this option, I think it will be ready already tomorrow :mrgreen:
So, thank you for your request ;)
Posted: Thu Jul 06, 2017 8:44 am
by Elite Admin S
The modified version is online!
Download it again and try, let em know if it works!
Posted: Tue Jul 11, 2017 12:17 pm
by loki
gonna try it out !
Posted: Tue Jul 11, 2017 7:11 pm
by loki
non conesso
Posted: Wed Jul 12, 2017 8:20 am
by Elite Admin S
The Real software was closed when you run the upgrade program?
Are you sure that your trainer was not connected to something else (app or devices)?
