real emotion resposiveness
i noticed a lag of 1-2 seconds until the magnet gives me the resistance of a slope in zwift ... is there any possibility to fasten this procedure ?
Re: real emotion resposiveness
It is due to how the trainer is made.
The trainer has a magnetic arm moved by a step motor, so it takes some seconds to put the arm in the correct position.
If you have a b+ version or an ant upgradable version of the firmware, you can indeed speed it up a little.
In this case, here's the link on how to do it (look for the part related to modification of the resistance variation speed:
http://com.elite.realaxiom.static.s3.am ... _eng_5.pdf
i have the b+ version and downloaded the tool for the b+ version but it told me that the trainer is not supported.
Sorry, I've verified and Real Emotion is already at its maximum speed.
This part of the procedure is almost only for Real Turbo Muin.
I'm sorry, it's not possible to speed it up.
@loki,
Good news!
I've talked with the developers again and they told me that they can indeed speed it up a little!
They are modifying the upgrade program to enable this option, I think it will be ready already tomorrow
So, thank you for your request
Good news!
The modified version is online!
Download it again and try, let em know if it works!
gonna try it out !
The Real software was closed when you run the upgrade program?
Are you sure that your trainer was not connected to something else (app or devices)?
