I have an original RealTour trainer but can't find the original installation software, and it's not obvious where to find the installer on the Elite site.
Can anyone direct me to where I can find the installer?
I'd like to use the trainer with Zwift, but Zwift doesn't recognize the RealTour trainer. I think I need to install the Elite software first.
Thanks...
Download For old Real Tour RealTour?
Re: Download For old Real Tour RealTour?
Problem solved-- the support staff at Real were able to provide the missing device driver to allow Windows to recognize the RealTour trainer.
The trainer works perfectly with Zwift and Elite's E-Trainer software.
Hi Roy, I have the same problem, please advise where i can down load the software for my real tour?
thanks
clive
thanks
clive
I was emailed a copy of the driver (CDM v2.12.00 WHQL Certified.rar) by the Elite support team, once I worked through a very long process of trouble shooting and discussion.
If you're willing to trust me, then you can get a copy at the link below:
https://www.dropbox.com/s/pyiu7ftr6iban ... d.rar?dl=0
If you want to get it directly from Elite, then contact them via the support links on the website, or maybe try emailing directly at real@elite-it.com. When you contact them, mention my support ticket #110251 to work through the discussion faster.
Good luck!
Good luck!
I have a Realtour ANT+ roler, I dowlooaded the myEtraining software to be able to use it on my new Laptop, but during the setting process eventhough the roller is listed it is not possible to pickup the protocoll type "ANT+" to complete the installation. does someboddy knows why and what to do ?
