I have the original Real Turbo Muin with the ant+ connectivity.
I was just wondering if something was released which enabled this to be compatible with bluetooth devices?
Cheers
Danny
Original Real Turbo Muin Bluetooth upgrade?
FISHER1985
Re: Original Real Turbo Muin Bluetooth upgrade?
Hi Danny
I confirm you that indeed we have a firmware update for the Real Turbo Muin ant, but it only enables the ant + fe-c protocol (so, you'll be able to use it with non-Elite apps and devices compatible with fe-c trainers, like Zwift software or the Garmin 1000 device. The bluetooth cannot be enabled, as your trainer electronic board doesn't have the bluetooth smart chip on board.
If you want to upgrade your trainer, here's the link with the complete procedure:
http://com.elite.realaxiom.static.s3.am ... ng_5_2.pdf
FISHER1985
thank you for information & the quick reply.
alan.weinberg
if the Real Turbo Muin B+ trainer is sent back to Elite could the board be replaced at factory?
Thanks.
Alan
Thanks.
Alan
If you have a Real Turbo Muin B+, you already have the latest version of the board. May I ask you why do you think you need to replace it?
