Rampa firmware update
leonardo_autilio
Postby leonardo_autilio » Wed Mar 29, 2017 9:19 pm
Dear friends,
What is the procedure to update the Rampa trainer to its latest firmware? I could not find this info anywhere.
Best Regards,
Leonardo
Re: Rampa firmware update
Postby Elite Admin S » Thu Mar 30, 2017 8:20 am
Hi Leonardo
May I ask you why do you think you need a new firmware? Do you have any problem with your Rampa?
We release firmware update only in particular cases (for example, we did it to add ant+ fe-c protocol to old ant trainers). It's not a standard procedure.
If in future we will release a Rampa firmware update, you'll find an announcement in this forum with all the details.
leonardo_autilio
Postby leonardo_autilio » Mon Apr 03, 2017 3:56 pm
Dear admin,
I have no problems with the trainer so far... I just want to make sure it was up-to-date with latest improvements and bug-fixes released by Elite.
I case of new firmware being released, would myETraining app alert me of a new firmware release or should I keep checking with forum?
Best Regards
Leonardo
Postby Elite Admin S » Tue Apr 04, 2017 8:10 am
The app won't give you any notification about new firmware. I suggest you to keep an eye on the announcement section of the forum.
jheeds
Postby jheeds » Mon May 27, 2019 9:45 am
Hi, has there been an update for the Rampa software to update to support FTMS? This was suggested that it was coming a long time ago but I can not locate any further information.
andiyatsia
Postby andiyatsia » Sun Jul 28, 2019 9:41 pm
jheeds wrote:Hi, has there been an update for the Rampa software to update to support FTMS? This was suggested that it was coming a long time ago but I can not locate any further information.
I have no problems with the trainer so far.. Tutuapp 9Apps ShowBox. I just want to make sure it was up-to-date with latest improvements and bug-fixes released by Elite.
potvrzeni.dan
Postby potvrzeni.dan » Tue Mar 10, 2020 9:52 pm
does Elite Rampa support firmware FTMS as it was promised in 2017?
Best regards
Daniel
Return to “Rampa”
