Track Bike with Elite Rampa
Element2k3
Postby Element2k3 » Sun Sep 10, 2017 12:22 am
Hello community,
I'm looking into buying the Elite Rampa but can't find any info about what axle size is supported. I'm planing to use the Rampa with my track bike that has a standard track hub with 120mm and bolts. Does the bike fit on the Rampa? Or do I need an adapter?
Dan
Re: Track Bike with Elite Rampa
Postby Elite Admin S » Mon Sep 11, 2017 9:16 am
Hi Dan
Don't worry, your bike is compatible with the frame of Rampa (it supports hub up to 175,4mm). You won't need any adapter.
Element2k3
Postby Element2k3 » Mon Sep 11, 2017 11:40 am
Thanks, that is some great news. And you really shoud advertise this seen that there are no information regarding 120mm hubs.
Return to “Rampa”
