Dear friends,
What is the procedure to update the Rampa trainer to its latest firmware? I could not find this info anywhere.
Best Regards,
Leonardo
Rampa firmware update
Re: Rampa firmware update
Hi Leonardo
May I ask you why do you think you need a new firmware? Do you have any problem with your Rampa?
We release firmware update only in particular cases (for example, we did it to add ant+ fe-c protocol to old ant trainers). It's not a standard procedure.
If in future we will release a Rampa firmware update, you'll find an announcement in this forum with all the details.
leonardo_autilio
Dear admin,
I have no problems with the trainer so far... I just want to make sure it was up-to-date with latest improvements and bug-fixes released by Elite.
I case of new firmware being released, would myETraining app alert me of a new firmware release or should I keep checking with forum?
Best Regards
Leonardo
Best Regards
Leonardo
The app won't give you any notification about new firmware. I suggest you to keep an eye on the announcement section of the forum.
Hi, has there been an update for the Rampa software to update to support FTMS? This was suggested that it was coming a long time ago but I can not locate any further information.
andiyatsia
jheeds wrote:Hi, has there been an update for the Rampa software to update to support FTMS? This was suggested that it was coming a long time ago but I can not locate any further information.
I have no problems with the trainer so far.. Tutuapp 9Apps ShowBox. I just want to make sure it was up-to-date with latest improvements and bug-fixes released by Elite.
potvrzeni.dan
does Elite Rampa support firmware FTMS as it was promised in 2017?
Best regards
Daniel
Best regards
Daniel
