Dear Elite
I have an Elite Qubo Digital Smart B+. When I connected my 935 to it via ANT+ I noticed that speed was completely off, showing me at up to 190km/h sometimes.
What shall i do?
Qubo Digital Smart B+ sync with Garmin 935.
Re: Qubo Digital Smart B+ sync with Garmin 935.
If you use a non Elite device/app to connect your Qubo Digital, you have to set in it a circumference value equal to the roller circumference (well, half roller, as it has two magnets inside). So, in your Garmin, set a circumference value of 47mm and speed should be correct.
Please notice that not all the devices allow to insert a so low circumference value!
Contact Garmin for any additional information
Hi, may I know the same information (measure to put in Garmin) for Elite Turno?
Thank you in advance
If you connect the trainer as speed&cadence sensor + power sensor, you have to insert your wheel circumference divided by 15.34
For example: 2095/15.34 = 137 mm
Users browsing this forum: No registered users and 42 guests
