Elite Novo Smart trainer calibration.
Posted: Wed Feb 14, 2018 11:20 am
by Robby
If you are using a 21 gear bike on the trainer, what gear should you be in when you do the calibration? I have not seen this mentioned anywhere. (P1, P2 and P3)
Re: Elite Novo Smart trainer calibration.
Posted: Fri Feb 16, 2018 12:37 pm
by Elite Admin S
Gear is not important. You have to use a gear that allows you to keep the speed as constant as possible when requested.
