Digital Qubo Wireless - Update?
Tarahs
Postby Tarahs » Fri Nov 05, 2021 12:13 pm
I have an Elite Digital Wireless code 0121004 (SN 5515), i heard about a firmware update: what does it change? How can I do that?
Also: how do i know if it has a 30 or 45 roll? [solved with a tape, it's diameter 30mm]
Also: The mini-PC seems to work, but if I connect my garmin fenix 5 it recognizes the sensor but the speed isn't working while on the ciclocomputer it does.
Any suggestions? thanks
PS: Info in italiano o in inglese va bene tutto :)
Re: Digital Qubo Wireless - Update?
Postby Elite Admin S » Wed Nov 10, 2021 10:59 am
Hi Tarahs
I'm going to reply in english, just for other people reading :geek:
First of all, you have to check the serial number of your Qubo Digital. It must be over 9784.
If it is so, you can upgrade it to make it ant+ fe-c compatible:
https://elitesrl.zendesk.com/hc/en-us/a ... on-Digital
To have the instructions on how to do it, please contact the customer care:
