I´m trying to change the values of P1, P2, and P3 to have a more realistic experience with the trainer. So I went to the app, changed the values, pressed ok, waited for the confirmation, and when I checked again, the old values are kept the same.
I´ve tried several times without success. I also power off the trainer, but the values still the same.
Any idea about how to fix this problem?
Wagner
Changing P1, P2, P3 values
Re: Changing P1, P2, P3 values
The values shown in the app are ALWAYS the default values, not the one set on the trainer.
So, it's normal that you always find the same values when you start the app
