Novo Smart: Erratic cadence readings
Posted: Fri Jan 29, 2021 6:40 pm
by mknbl.56
My novo smart trainer has been working fine, but the last couple of times I've used it the cadence readings are all over the place
one second they ore 60-70 then jump to 190 then down to 40 continually changing
power /speed readings are all OK and look to be about right
the same thing happens in zwift Elite my training and other apps so it seems to be a sensor issue rather than the receiving apps
how can I fix this
Re: Novo Smart: Erratic cadence readings
Posted: Fri Feb 19, 2021 7:45 pm
by jdbates93
I'm having exactly the same issue.
Anybody else?
