Page 1 of 2
Digital Qubo Wireless and Garmin 520
Posted: Tue Jul 11, 2017 11:38 pm
by eliteit
Hi - is the Digital Qubo Wireless compatible with the Garmin 520?
Thanks.
Re: Digital Qubo Wireless and Garmin 520
Posted: Wed Jul 12, 2017 8:23 am
by Elite Admin S
The Qubo Digital Wireless it's not compatible with Garmin 520.
But, if it is the upgradable version, you can do the upgrade to fe-c and then connect with it.
Can you tell me the serial number of your trainer?
Posted: Wed Jul 12, 2017 5:38 pm
by eliteit
Hi - it's Q14239.
Thanks!
Posted: Thu Jul 13, 2017 8:17 am
by Elite Admin S
I confirm that it is upgradable. After the upgrade, you'll be able to connect it with the garmin.
Please notice that:
- to upgrade the trainer, you need a pc and a ant+ dongle
- after the upgrade, you won't be able to connect the handlebar console anymore
- after the upgrade, the trainer will be fe-c compatible so if you use the my e-training app you have to select "qubo digital interactive"
If you decide to do the upgrade let me know, we'll send you the instructions on your forum email address
Posted: Thu Jul 13, 2017 3:24 pm
by eliteit
Yes please - send the instructions
Thanks!
Posted: Fri Jul 14, 2017 8:34 am
by Elite Admin S
Sorry, we have some problems sending you the instructions to your forum account address.
Please write me a pm with a different email address
Posted: Fri Jul 14, 2017 9:01 am
by eliteit
I've just sent a PM.
The message has appeared in my Outbox - have you received it?
Posted: Fri Jul 14, 2017 9:05 am
by Elite Admin S
Received!
We're going to send you the instructions
Posted: Fri Aug 11, 2017 9:41 am
by eliteit
Hi - please can someone contact me. The instructions sent didn't work. I get "Upgrade not possible" error.
Posted: Mon Aug 28, 2017 8:26 am
by Elite Admin S
Please contact our customer care and add the log report of the upgrade procedure.
