Hello everybody
Greetings from Chile
Just bought an Elite Qubo Digital which says to be BT and Ant+ compatible.
During setup I tried to pair my Fenix 3HR HR-RUM band with the digital unit with no success. I get Err, press the left button to pair again and continually get the Err message.
Please Advise
Best Regards
Rafael
can't pair garmin HRM RUn HR band
Re: can't pair garmin HRM RUn HR band
Hi Rafael
If you have the handlebar console, it means that you have the Qubo Digital (first version), which doesn't have the bluetooth compatibility.
It uses a proprietary ant protocol.
The old Qubo Digital can be coupled with any ant+ heart rate transmitter.
I don't know how your Fenix works, unfortunately. Please contact Garmin and ask them if the device transmits externally an ant+ heart rate signal.
If it is so, you should be able to couple it.
